Enable Second NIC on Cold Standby Server for maintenance (UCCX 7.01)
Apr 16th, 2009
When i enable the second nic on uccx 7.01 the node manager wont start.
I would like to enable it so i can do maintenance on a cold standby server that can't have the first nic active.
Is there anyway to use the second nic to do this without killing node manager?
thanks in advance,
met.
Anonymous (not verified) Wed, 04/22/2009 - 13:10
On CRS server if you go to Network and Dial-up Connections and then from toolbar -> Advanced-> Advanced Settings and check Local Area Connection's Order. Switch them that CRS NIC is first in the list.
metalium2007 Wed, 04/22/2009 - 13:31
Thanks, but i realized it before as in another post.
Anyway there's a score for your kindness.
rgds,
met.
