877W - Unable to enter ROMMON/no password recovery
Apr 16th, 2009
I have just bought an 877W router from a company that has gone in to administration but cannot perform a password recovery. The recovery function has been turned off but having read the proceedure on Cisco's web site thought I would be able to sort it.
Unfortunately when ever I try it takes no notice of the break key and just loads the original config.
I know my break key is OK as I can use it on a Cisco 2503 and 878.
I've tried break within 60 seconds, just as the image is actually loading and also when the 'image text base' line appears but to no avail.
The image is c870-advipservicesk9-mz.124-9.T2.bin
Any help would be greatly appreciated.
Thanks.
Paul.
Overall Rating: 5 (1 ratings)
paulmoore69 Thu, 04/16/2009 - 12:40
Tried this one as well but still no joy. Thanks for reply though.
Leo Laohoo Thu, 04/16/2009 - 14:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Rename the image with a different file extension.
paulmoore69 Fri, 04/17/2009 - 00:44
Sorry, I may be missing something but how as I do not have access to configure the router.
Joseph W. Doherty Fri, 04/17/2009 - 03:56
Unsure whether the 877W supports it, but later devices support disabling password recovery as a security option.
If this is supported on the 877W and if it had been activated, from other router documentation, you need to physically replace ROMMOM. (I.e. there's no "soft" recovery method.)
Leo Laohoo Fri, 04/17/2009 - 20:52
  • Hall of Fame,
    2017 LAN, Wireless
Hi Paul,
Some months ago, I read some instructions to do password recovery even when the function has been disabled. Unfortunately, you'll need to Google it.
Leo Laohoo Sun, 04/19/2009 - 19:26
  • Hall of Fame,
    2017 LAN, Wireless
Hi Paul,
Found it!
Here's the link:
http://www.heinzulm.com/password.php
Hope this helps.
paulmoore69 Wed, 04/22/2009 - 01:53
Thanks, but still no joy. It appears as the router cannot see an image to boot from it reloads and the cycle begins again.
Normally after 3 cycles it would drop in to ROMMON but because of the no password recovery it cannot do this.
As someone suggested above looks like I need to replace the eeprom/ROMMON........any ideas how??
Leo Laohoo Wed, 04/22/2009 - 14:24
  • Hall of Fame,
    2017 LAN, Wireless
Hi Paul,
If you noticed on the link posted, it's a "timing" thing when to invoke the BREAK sequence. Did you try that method out and it still doesn't work?
paulmoore69 Thu, 04/23/2009 - 02:53
I have found a solution now!!
If you press the reset button on the rear of the router within 5 seconds of powering it up and leave it, it will wipe the config and boot up as if it was a new router.
Thanks for everyones suggestions, much appreciated.
Paul.
narendrakumar1987in Tue, 05/18/2010 - 23:42
Hey Paul...
       Your solution helped me today... Thankyou
Happy Networking !!!
Narendrakumar B
paolo bevilacqua Wed, 05/19/2010 - 00:13
  • Hall of Fame,
    Founding Member
The only ABSOLUTE thing in the "method" linked above is BS, as the log itself show he did not really cracked anything! Ridicoulous!
