ASA 5520 VPN question
Apr 16th, 2009
I have the VPN groups setup and can VPN in from the outside of the network. When I do I get assigned an address from the address pool that I setup, but I cannot access the internet, or ping anything on the outside (example yahoo.com). I believe it may be a routing issue, but I cannot figure it out. Any help would be appreciated.
JORGE RODRIGUEZ Thu, 04/16/2009 - 19:24
  • Green, 3000 points or more
If your RA tunnel is configured as full tunnel and want to have VPN network access to internet you need couple of config statements to accomplish that.
See this link Public Internet VPN on a Stick Configuration Example
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805734ae.shtml
Exmaple:
Your RA VPN Pool net 192.168.10.0/24
same-security-traffic permit intra-interface
global (outside) 1 interface
nat (outside) 1 192.168.10.0 255.255.255.0
milldarr Fri, 04/17/2009 - 07:12
Thank you for the reply. Here is the config from the ASA, there are other config lines in it because I use it as a main firewall also. I am currently trying to get the vpncity group to work at first. I will send it in two or three parts. Thank you for your help.
ASA Version 7.0(6)
hostname COP-ASA
domain-name cityofpocatello.org
enable password 1aGFu1LmnjZMjYOU encrypted
names
dns-guard
interface GigabitEthernet0/0
nameif Outside
security-level 0
ip address 74.81.5.2 255.255.255.224
interface GigabitEthernet0/1
nameif Inside
security-level 100
ip address 10.2.0.253 255.255.254.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
nameif DMZeng
security-level 50
ip address 67.129.130.22 255.255.255.248
interface Management0/0
shutdown
no nameif
no security-level
no ip address
passwd 1aGFu1LmnjZMjYOU encrypted
ftp mode passive
clock timezone MST -7
clock summer-time MDT recurring
object-group service LicenseServerIPRange tcp
description ESRI License server ports
port-object range 27000 27010
access-list inside-to-engdmz extended permit ip any 67.129.130.16 255.255.255.248
access-list inside-to-engdmz extended permit ip any 10.2.0.128 255.255.255.248
access-list inside-to-engdmz extended permit ip any 10.2.0.144 255.255.255.240
access-list inside-to-engdmz extended permit ip 10.2.0.0 255.255.254.0 10.2.0.144 255.255.255.240
access-list acl-dmzeng extended permit tcp host 67.129.130.20 host 10.2.0.24 eq 1433
access-list acl-dmzeng extended permit tcp host 67.129.130.20 host 10.2.0.24 eq 5151
access-list acl-dmzeng extended permit tcp host 67.129.130.20 host 10.2.0.24 eq 5152
access-list acl-dmzeng extended permit tcp host 67.129.130.20 host 10.2.0.24 eq 5153
access-list acl-dmzeng extended permit tcp host 67.129.130.20 host 10.2.0.24 object-group License
verIPRange
access-list acl-dmzeng extended permit tcp host 67.129.130.20 host 10.2.0.24 eq 135
access-list acl-dmzeng extended permit icmp host 67.129.130.20 10.2.0.0 255.255.0.0
access-list acl-dmzeng extended permit icmp host 67.129.130.20 any
access-list acl-dmzeng extended permit tcp any any eq www
access-list acl-dmzeng extended permit tcp any any eq 8080
access-list acl-dmzeng extended permit udp any any eq domain
access-list acl-dmzeng extended permit udp any any eq 443
access-list out-acl remark *** DMZeng ***
access-list out-acl extended permit tcp any host 67.129.130.20 eq www
access-list out-acl extended permit tcp host 204.134.195.24 host 67.129.130.20 eq 5151
access-list out-acl extended permit tcp host 204.134.195.24 host 199.104.18.19 eq 5151
access-list out-acl remark *** end DMZeng ***
access-list out-acl extended permit icmp any any echo-reply
access-list out-acl extended permit icmp any any time-exceeded
access-list out-acl extended permit icmp any any unreachable
milldarr Fri, 04/17/2009 - 07:14
tunnel-group vpntest type ipsec-ra
tunnel-group vpntest general-attributes
address-pool Address_Pool
default-group-policy vpntest
tunnel-group vpntest ipsec-attributes
pre-shared-key *
tunnel-group vpncity type ipsec-ra
tunnel-group vpncity general-attributes
address-pool (Inside) Address_Pool
authentication-server-group Radius
authentication-server-group (Inside) Radius
default-group-policy vpncity
tunnel-group vpncity ipsec-attributes
pre-shared-key *
peer-id-validate cert
: end
