Cisco-Energywise-Mib Help
Apr 16th, 2009
We need to implement an emergency workaround to protect our environment based on the
recently released bugID CSCsy4140.
Our objective is to implement a snmp-server view which prevents access to any SNMP OIDs
that are identified in the CISCO-ENERGYWISE-MIB to prevent the possibility of triggering
this apparent memory leak.
Unfortunately, bugID CSCsy4140 is flagged as internal and contains no more publically
viewable information. Additionally, the CISCO-ENERGYWISE-MIB is not currently published on
CCO or available through any other means I could find.
Is is possible to be done.
Please check and suggest.
We are seeking only the information required to build an effective snmp-server view
(cutdown) to prevent access to any OIDs that are associated with EnergyWise MIB in order
to temporarily mitigate this vulnerability until such time where a device running
vulnerable code can be upgraded to the fixed version <12.2(50)SE1>.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 04/16/2009 - 15:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is not a valid bug ID. It's missing a digit.
Joe Clarke Thu, 04/16/2009 - 15:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Found the bug, CSCsy41470. The affected branch is cewEntTable. You can exclude 1.3.6.1.4.1.9.9.683.1.6 in your SNMP view.
