BLF For Phone State
Apr 16th, 2009
Hi All,
Is there any way of using a BLF to monitor the state of a phone. (Not the state of individual lines)? I have a customer that needs to monitor around 10 phones, each with at least 4 lines.
This is on ucm 6.1.3
Jaime Valencia Thu, 04/16/2009 - 15:28
no, BLF is per-line function
try installing the AC client on his pc to monitor the lines in the directory
if you have presence you can see the status in the directories, CUPC
java
if this helps, please rate
