"Show Log" question off a Cisco Router
Apr 16th, 2009
So this is probably a very easy question and I've done some searching on the net but can't seem to find an answer.
Does anyone know what the asterisks * means when in front of any given log entry?
I noticed that some log entries have them, yet some don't.
Example:
*Apr 16 10:53:14.454 EDT: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.0.0.2 on interface GigabitEthernet0/1
*Apr 16 11:07:19.002 EDT: %CLEAR-5-COUNTERS: Clear counter on all interfaces by localadmin on vty0 (10.10.2.21)
Apr 16 17:21:40.949 EDT: %PIM-5-NBRCHG: neighbor 10.0.0.1 DOWN on interface GigabitEthernet0/1 non DR
Apr 16 17:21:53.494 EDT: %PIM-5-NBRCHG: neighbor 10.0.0.1 UP on interface GigabitEthernet0/1
I know it's meaningless but I'm curious. Any insight would be greatly appreciated.
Overall Rating: 3 (2 ratings)
Leo Laohoo Thu, 04/16/2009 - 18:05
Yes. It means that during the time, your clock was not synchronized to an authoritative source.
mortonjes Thu, 04/16/2009 - 19:44
Thanks for the reply but wouldnt the routers own clock be an authoritative source?
Your help is greatly appreciated!
Leo Laohoo Thu, 04/16/2009 - 19:59
Depends on the router. New generations of routers, 1800, 2800, 3800, have built-in clocks. Older ones don't.
Joseph W. Doherty Fri, 04/17/2009 - 03:31
"Thanks for the reply but wouldnt the routers own clock be an authoritative source? "
Probably not unless you define the device as a NTP master.
PS:
BTW, often overlooked, you can sync the on-board clock (not just the running clock) to NTP. (Helps insure more accurate time logging during boot and until sync'ed with an external time source.)
