cbwfq classes with traffic matching multiple classes
Answered Question
Apr 16th, 2009
Using CBWFQ with access-lists to match traffic assigned to classes. If access-lists are not very specific, what happens to traffic that is matched by 2 or more access-lists i.e. traffic could be put multiple classes?
What is the process for the router uses to determine which class to assign that traffic too?
thanks
Peter
Correct Answer by Giuseppe Larosa about 8 years 2 months ago
Hello Peter,
the order of referring of the class-maps in the policy-amp config counts and so traffic will match on only one class the first one in the order for which the traffic flow matches a criteria like an ACL.
you can see the order in the output of
sh policy-map
This is not good practice and should be avoided if possible by defining ACLs with no possible matches in common for a clean configuration.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 04/16/2009 - 23:17
  • Hall of Fame,
    Founding Member
Hello Peter,
sh policy-map
Hope to help
Giuseppe
