modify calling name in H.323
Apr 16th, 2009
Hi All,
Is there a way to change/modify calling name of inbound call coming from isdn ? currently, when calls come in , the calling name is empty (blank). I wonder if there is a way to fill the field.
Regards.
bigcappa1 Mon, 04/20/2009 - 23:44
The inbound calling name I suppose will depend on your Telco facilities and your country. It can be done howover using CallTracer. Which basically just does a lookup of a defined table. and then makes the name appear if it can cross reference the number. Here is the link
http://www.myvoipsource.org/tools/
Paul
0600648902 Wed, 04/22/2009 - 19:48
Hi Paul,
Thank you for the information. I read that CallTracer is used for call manager. is there a way we can do it for call manager express ?
Regards.
antzoulis Fri, 03/05/2010 - 16:32
If I wanted to use a local text file for the lookup, what format in the text file should it be ?
