Alternate method to Xmodem
Answered Question
Apr 16th, 2009
Hi All, I have a switch that a co-worker, while trying to upgrade the IOS, in the process deleted the existing IOS without successfully uploading the new IOS. Anyway I'm at the point of upgrading through Xmodem but, I have to imagine there is a quicker method.
Here are the details on the switch
Cisco 3750-48T
Any suggestions?
thanks,
Mike
Correct Answer by Joseph W. Doherty about 7 years 11 months ago
Also, if your 3750 and terminal simulator supports something better than Xmodem, use the better protocol. (Even Xmodem-1K.)
PS:
Unsure, but some hosts and Cisco devices might support even faster than 115K, if they do, use it.
Also, if you can, you might want to reset BAUD rate before actual reload. Otherwise, it might become the new default speed, which makes it difficult to get on the device at 9600 next time you need to.
Overall Rating: 5 (1 ratings)
Leo Laohoo Thu, 04/16/2009 - 21:33
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Other than X-Modem at 9600? Try changing the baud settings to 115K.
davy.timmermans Thu, 04/16/2009 - 23:54
  • Silver, 250 points or more
As above said:
set BAUD 115200
disconnect the session and reconnect with the correct BAUD setting
Correct Answer
Joseph W. Doherty Fri, 04/17/2009 - 03:22
PS:
carbonscoring Fri, 04/17/2009 - 14:38
Thanks guys for your help, I wasen't able to TFTP I looked it up and you can only use this for Routers. I forgot about what Joseph said about reseting the Baud rate before reloading. Wasent a big issue I just had to reboot back into ROMMON mode and set the Baud rate from there.
thanks,
Mike
