cisco 2811 dhcp relay configuration
Apr 16th, 2009
we ahve dhcp server in one lan segment 192.168.20.x, we are planing to create another lan segement for which we want to use same dhcp server , we configure scope for two segment in dhcp server.
do let e know how can i configue dhcp relay on cisco 2811 to successfully relay dhcp trafic to dhcp server..
Nilesh G.
enkli Thu, 04/16/2009 - 23:41
on the indetface of the 2811 from th cli you mus configure dhcp-relai ip of the dhcp server.
if you want to have dhcp on two int. you mus configure it on each.
the option is not ont th SDM
imnilesh Thu, 04/16/2009 - 23:51
Thanks for relpy ENKLI,
configured ip address-helper command on router interface to forward dchp broacast to dhcpserver
NIlesh G
