RADIUS Port on 7204 VXR
Apr 17th, 2009
I have a Cisco 7204VXR Router running c7200p-ipbasek9-mz.124-4.XD5.bin IOS. However, the router only uses the extended source ports (21645 to 21844) for RADIUS authentication despite using the command
"no radius-server source-ports extended"
and reloading. Is there another way to force the router to use the default RADIUS source ports(1645 and 1646)?
Giuseppe Larosa Fri, 04/17/2009 - 08:06
Hello Adetola,
have you tried to specify the ports in the same line where you define the radius server ip address ?
Hope to help
aoyawale Fri, 04/17/2009 - 08:10
Hi Giuseppe,
Thanks for your response. I've tried that before and it gives an error at the point where I typed the port number.
aoyawale Mon, 04/20/2009 - 01:09
Hi Giuseppe,
Unfortunately the hardware has been shipped top site. However, I'll try the setup in GNS3 and let you know the outcome.
