04-17-2009 02:21 AM - edited 03-06-2019 05:14 AM
hi all
I need to create management vlan with ip 11.14.10/24 in the catalayst 6500 seris switch
the gate way ip to be used for new vlan willbe 11.14.10.1
could you please any one tell me how to configure with commads and please share me the documnet
alos please let me know i have to create this vlan in MSFC only or on both
regards
Aravind
04-17-2009 03:07 AM
Aravind
Could you answer the following
1) what version of software is your 6500 running ?
2) Do you know if it is hybrid or native mode ?
3) the management vlan - does it already exist as a vlan on the switch ?
4) If not 3) then is the switch a VTP client or server or transparent
5) Where will 11.14.10.1 address be allocated ie. is it on the 6500 or a different device ?
Jon
04-17-2009 03:37 AM
You are saying both so we will assume hybrid.
On the catos side for an example. This vlan would then need to be allowed down any trunks where you will be using this management vlan .
set vlan 2 name mgt-vlan
Layer 3 side
Interface vlan 2
ip address 11.14.10.1 255.255.255.0
no shut
04-17-2009 03:44 AM
ANs:cat6000-supk8.7-6-11.bin
A:its inhybrid mode
i think it new vlan can u tell me how to check based on name and ip address
A:Server mode( sh vtp dom
Domain Name Domain Index VTP Version Local Mode Password
UUUUU 1 2 server configured
I think we have to give it int MSFC card Since we have to configure hsrp
thanks
Aravind
04-17-2009 03:51 AM
Aravind
Glen has given you most of what you need ie.
Layer 3 side
Interface vlan 2
no shut
to check if vlan 2 exists already on the switch from the prompt - "sh vlan" will show if it is there already. If not do as Glen suggests.
The switch part in hybrid has an sc0 interface for management so in addition to Glen's post you also need
switch(config)# set int sc0 11.14.10.2 255.255.255.0
switch(config)# set int sc0 2 <-- this configures the management interface to be in vlan 2.
Jon
04-17-2009 04:01 AM
Dear ALl
Thanks for the quick help
already managemet interface presents:plz find below conf
#ip
set interface sc0 3 11.50.208.41/255.255.255.0 11.50.208.255
set interface sl0 down
set interface sc1 1 0.0.0.0/0.0.0.0 255.255.255.255
set interface sc1 down
set ip route 0.0.0.0/0.0.0.0 11.50.208.1
ALL i need to create one more L3 vlan ON MSFC card with HSRP
how should i allow this vlan to pass through trunks
please give with the commads, as i am new cisco switching
thanks
Aravind
04-17-2009 05:29 AM
Aravind
On switch -
set vlan 10 name mgmt
on MSFC1
int vlan 10
ip address 11.14.10.2 255.255.255.0
standby 10 ip 11.14.10.1
standby 10 priority 110
standby 10 preempt
standby 10 authentication
on MSFC2
int vlan 10
ip address 11.14.10.3 255.255.255.0
Jon
04-17-2009 06:51 AM
Dear All
Thanks to every one for the posts
can please clarify i have to allow or have to do with trunking
aravind
