CUCM 7.x CSS Interaction with CUC 7.x Restriction Tables
Answered Question
Apr 17th, 2009
Guys - Can anyone clarify the relationship between the VM Port CSS and the CUC Restriction Tables for Call Handler transfers?
My scenario is:
Call Handler A is set to transfer out to PSTN number when option 1 is selected. My understanding is this will not work until the VM Port has CSS set with the correct PTN to dial this number AND the CUC System Transfer Restriction Table is updated to allow this number. However, this looks to work when CSS is set on VM port and nothing is changed on the restriction table (which should block by default).
Brian
Correct Answer by Rob Huffman about 8 years 2 months ago
Hi Brian,
I have to agree with your understanding of this setup. There are some bugs related to the Restriction Tables in UC 7.0 so I would probably refer this to TAC. I know this doesn't sound exactly like your issue but is similar;
CSCsy93975 Bug Details
default system transfer retriction table sometimes not followed
Symptom:
Under some circumstances yet to be determined, changes made to the default system transfer restriction table are not adhered to with outbound transfers.
Conditions:
First discovered in Unity Connection 7.0.1ES38.21020-38
Only happens if you have made customizations to the default system transfer restriction table.
Workaround:
None established at this time.
Further Problem Description:
The appearance of the system default transfer rules table in tbl_RestrictionPattern in this situation still appears to be configured as desired Status
Fixed
Severity
2 - severe
Last Modified
In Last 3 Days
Product
Cisco Unity Connection
Technology
1st Found-In
7.0(1)
Fixed-In
7.0(2)ES10
7.0(2.21009.1)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 04/17/2009 - 05:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Brian,
Symptom:
Conditions:
Workaround:
Fixed
Severity
2 - severe
Last Modified
In Last 3 Days
Product
Technology
1st Found-In
7.0(1)
Fixed-In
7.0(2)ES10
7.0(2.21009.1)
Hope this helps!
Rob
btmulgrew Fri, 04/17/2009 - 05:55
Thanks a lot Rob - this does look very similar. Will keep the CSS on VM Ports restricted to dial only those required numbers as a precaution!.
Thanks again
Brian
