Login only on business hours
Apr 17th, 2009
  • Silver, 250 points or more
Is there a way in order to enforce the authentication (telnet, shh) on switches and/or routers local or via RADIUS only on business hours?
Thank you.
Best regards.
Massimiliano.
Overall Rating: 2.5 (2 ratings)
AxiomConsulting Fri, 04/17/2009 - 05:31
What RADIUS are you using?
You can edit the Profile, if using MS IAS and edit the option 'Allow access only on these days and at these times'
Steve
massimiliano.se... Mon, 04/20/2009 - 00:45
I'm using FreeRADIUS...
Thank you.
Best regards.
Massimiliano.
massimiliano.se... Mon, 04/20/2009 - 04:02
I've resolved.
In FreeRADIUS the attribute is "Login-Time"...
For examople in order to permit the login to one user only on interval range 8:00-24:00 on all days of the week we use Login-Time:='Al800-2400'
Best regards.
Massimiliano.
John Blakley Fri, 04/17/2009 - 05:34
  • Purple, 4500 points or more
In theory, you should be able to create an access list that's time based and then apply it to your line.
router(config)# time-range TEST
router(config-time-range)# periodic weekdays 08:00 to 17:00
router(config-time-range)# ip access-list ext ALLOWEDTELNET
router(config-ext-nacl)# permit tcp any any eq 23 time-range TEST
router(config-ext-nacl)# line vty 0 4
router(config-line)# access-class ALLOWEDTELNET
I've never tried this, but it should work.
HTH,
John
