Switch 4507 data flow.
Apr 17th, 2009
Hi All,
I am at strange.
We have one primary location as DC at Odense
we have one Core switch (4507) here and all servers directly connected to this one.
One MPLS line with 2 MB speed connected to this switch only.
we have many remote locations and those all will be access DC through MPLS line only
Here I want which port utilising more bandwidth or in / out data flow.
NOTE: the core switch does not support to enable #ip flow cache & #ip counters
Is there any other ways how we can get exactly which port how utilizating
I already verified with command #sh int stats but we have to check this pirodically if we want correct figure for particular time frame.
Giuseppe Larosa Fri, 04/17/2009 - 08:38
  • Hall of Fame,
    Founding Member
Hello Naidu,
on C4500 you can use
sh int summary it provides numbers one line for each port
Example:
sh int summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
Vlan1 0 0 0 0 0 0 0 0 0
* Vlan301 0 0 0 0 1000 1 1000 1 0
* GigabitEthernet1/1 0 0 0 0 324477000 40299 52306000 20610 0
* GigabitEthernet1/2 0 0 0 0 53000 56 1000 3 0
GigabitEthernet2/1 0 0 0 0 0 0 0 0 0
* GigabitEthernet2/2 0 0 0 0 0 0 0 0 0
* GigabitEthernet2/3 0 0 0 0 16000 8 15000 10 0
* GigabitEthernet2/4 0 0 0 0 0 0 1000 2 0
* GigabitEthernet2/5 0 0 0 0 0 0 4000 5 0
* GigabitEthernet2/6 0 0 0 0 0 0 5000 6 0
* GigabitEthernet2/7 0 0 0 0 0 0 1000 2 0
* GigabitEthernet2/8 0 0 0 0 0 0 0 0 0
* GigabitEthernet2/9 0 0 0 0 9000 10 12000 14 0
Hope to help
Giuseppe
