How to configure sending DTMF codes for a long distance provider via ISDN?
Apr 17th, 2009
I've cisco 3825. I want to configure sending DTMF codes after call setup to long distance provider.
I solve this in fxo by dial-peer configuration:
dial-peer voice 107 pots
trunkgroup common
permission term
description From Common - test
destination-pattern 11005318751
prefix 11005318751,,,,,,,,,,42641980255
But this configuration doesn't work for isdn.
I think only tcl can solve my problem. I'm right?
CHRIS CHARLEBOIS Fri, 04/17/2009 - 12:18
ISDN doesn't use DTMF for call setup which is why the configuration you have used for POTS doesn't work. The gateway collects all digits and send it out in a H.225 setup message, rather than playing it out over the voice channel.
As for how to do that... There maybe an option using a custom made TCL script/application, but it would definitely be a solution that was outside the box. I'm afraid I don't know TCL well enough be help you out there.
