Ethernet channel between routers
Jon Marshall Fri, 04/17/2009 - 05:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
Do you mean an etherchannel connection between the 2 routers ?
Jon
thotsaphon Fri, 04/17/2009 - 07:02
  • Gold, 750 points or more
John,
Built-in Ethernet interfaces of 3725 and 2620XM can't perform etherchannel functions. You need HWIC-4ESW card or something like that to do so.
Multilink would be Point-to-Point Protocol story.
HTH,
Toshi
Giuseppe Larosa Fri, 04/17/2009 - 07:12
  • Hall of Fame,
    Founding Member
Hello John,
between two routers I would use IP load balancing using two indipendent L3 links.
Both static routes or a dynamic routing protocol of your choice can handle two equal cost paths.
Normal CEF load balancing uses an exor of IP SA and IP DA and an hash (seed).
So packets of each flow follow a single path for each direction.
If multiple traffic flows are present you should get fair usage of the two links in both directions.
Hope to help
Giuseppe
