Interconencting 2 PBX's(TDM based) using T1 Trunk Voice WAN Int
Hi Experts,
We are planning to migrate our existing WAN to an L3 MPLS cloud.
We currently have 2 PBX's connected via dedicated links. These PBX's are pure TDM based.
Can we connect these to Cisco routers using the T1 voice card(part#VWIC2-1MFT-T1/E1) and route the trafic over the MPLS cloud. Also how do we tell the Cisco router at site A that it needs to send the PBX traffic to the router at Site B.
Would appreciate if someone can provide some guidance.
Imran.
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Fri, 04/17/2009 - 06:13
Yes. You also need the PVDM2 DSP module, like a -32 size. Then you need to get familiar with the voice configuration or hire someone that is.
Paolo Bevilacqua Fri, 04/17/2009 - 06:23
The DSP are necessary for voip.
You can enter "pbx trunking" and get many results from the search box.
