2801 Gateway will not Register CM
Answered Question
I am trying to add a gateway to my CM ver 6.1.2.1000-13. I set the MGCP 2801 Gatway in the CM and configure the router but it does not register. The router can communicate fine with the CM.
Router Info:
cm-manager mgcp
ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.16.101.5
ccm-manager config
mgcp
mgcp call-agent CCM01 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Vlan169
mgcp bind media source-interface Vlan169
mgcp profile default
sccp local Vlan169
sccp ccm 172.16.101.5 identifier 1 version 6.0
sccp
sccp ccm group 1
bind interface Vlan169
associate ccm 1 priority 1
sh ccm-man
MGCP Domain Name: RONS_GW
Priority Status Host
Primary Registering with CM CCM01 (172.16.101.5)
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 09:42:39 NewYork Apr 17 2009 (elapsed time: 01:)
Last MGCP traffic time: 10:44:28 NewYork Apr 17 2009 (elapsed time: 00:)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
Current version-id: 1239893703-95f85d57-4795-4c67-83d6-8b7edf45a5e4
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: cisco
Configuration Error History:
RONS_GW#sh ver
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 12.4(22)T,)
Any ideas where to start ?
Correct Answer by Nicholas Matthews about 8 years 1 month ago
Make sure that in CUCM you have the gateway defined like you see in this output:
"show ccm | i Domain Name"
As well, make sure you have 'isdn bind-l3 ccm' on your Serial 0/0/0:23 interface, and that your controller has 'pri-group time 1-24 service mgcp'.
If it's not a PRI then you should make sure the FXO/FXS port has 'service mgcpapp' under the dial-peer voice x pots dial peer.
Otherwise, check 'show voice port summary' and 'show voice call summary' to see if the port is in a bad state.
-nick
Overall Rating: 5 (4 ratings)
Jaime Valencia Fri, 04/17/2009 - 08:19
  • Cisco Employee,
  • Hall of Fame,
    2011
try changing this to IP
make sure in CUCM it's hostname.domain.com if you have it configured in the router
try a no mgcp/mgcp
java
if this helps, please rate
Rob Huffman Fri, 04/17/2009 - 08:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ron,
Just to add on to the great tips from Java (+5 points today Java - Happy Friday :)
The Domain name issue is outlined nicely in this doc;
MGCP Gateway Registration Failure with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805a316c.shtml#prob
If the IP domain name is configured in Cisco IOS on the MGCP gateway, enter the Fully Qualified Domain Name (FQDN) in the Domain Name field.
In the example: test and cisco.com represent the hostname and domain name respectively. If the IP domain name is not configured in Cisco IOS on the MGCP gateway, enter only the hostname of the MGCP gateway in the Domain Name field.
You would enter test.cisco.com (in CCM)
Hope this helps!
Rob
Thanks for the help but it did not fix the problem. I confirmed that the gateway did not have a domain name and that the CCM01 did resolve in the right IP address.
I then added a Domain name to both and it still would not register.
I know that the Gateway is resolving the host name to the right IP. How does the CM resolve the domain name back to the gateway?
I am using Call Manager Business Edition is there a limit to the number of Gateways that it can have. I have. I have seven H.323 gateways and I am trying to set up my second 2801 MGCP gateway?
I also restarted the Cisco RIS Data collector but it did not help.
iptuser55 Fri, 04/17/2009 - 10:33
  • Silver, 250 points or more
Do a debug mgcp packets and then conf t no mgcp, mgcp
The debug commend will show the registeration process of the GW. If you see 200 response then the Hostname is ok if you see 500 check the hostname of the GW against the name in the GW config. in CCM. Also check whether you have ip domain-name? configured in the GW if so remove it
This is the debug output and I am getting a 500. I changed the hostname in the GW to RONS and the Domain name to RONS but it did not change.
*Apr 17 19:25:32.063: MGCP Packet sent to 172.16.101.5:2427--->
RSIP 993904705 [email protected] MGCP 0.1
RM: restart
*Apr 17 19:25:32.079: MGCP Packet received from 172.16.101.5:2427--->
500 993904705
Correct Answer
Nicholas Matthews Fri, 04/17/2009 - 12:09
  • Red, 2250 points or more
-nick
