Transfer CUE voicemail to another system - Unity 4.0
Apr 17th, 2009
Is there any way to transfer a CUE voicemail to a user on a different system - Unity 4.0 if on-net dialing is enabled? Is there any configuration that can be used to redirect it to the other system? If not, is there a way to extract the file from the router?
Rose
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 04/17/2009 - 10:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rose,
You could configure IMAP access on CUE and you would then have the ability to save the Voicemail as a .wav file. Or you could network the two systems together via VPIM;
IMAP;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/administrator/voicemail/12advVM.html
Configuration Example: Cisco Unity Express Networking
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00804dfe88.shtml#introduction
Hope this helps!
Rob
roseeng69 Fri, 04/17/2009 - 11:25
Hi Rob,
Thanks so much for the information! I'm going to try the IMAP solution.
Regard,
Rose
Rob Huffman Fri, 04/17/2009 - 12:22
  • Hall of Fame,
    Founding Member
Hi Rose,
You are most welcome my friend!
Cheers!
Rob
