Confirmation on 'storm-control broadcast' command
Answered Question
Apr 17th, 2009
Folks, if I use the config below on my 6513, what will be the action taken if broadcast levels go let's say, 20%?
I mean, I want to confirm that the below is enough to prevent action against broadcast, or in addition to the command below, I need to do "#storm-control action..." as well?
int f3/1
switchport
switchport mode access
no ip access
storm-control broadcast level 15.00
storm-control muticast level 15.00
end
Correct Answer by Giuseppe Larosa about 8 years 1 month ago
if inbound broadcast traffic is more then 15% in a 1 second interval it is dropped.
No additional action should be needed.
Verify the type of linecard you have because there are some differences
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/storm.html
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 04/17/2009 - 09:36
  • Hall of Fame,
    Founding Member
see
Hope to help
Giuseppe
