Cisco Licensing
Apr 17th, 2009
My question is this:
I have a 2811 router with the IOS feature set IP Base installed.  I need to upgrade to the Advanced IP Services feature set in order to build the configuration I need.  The router is under a Smartnet contract.
Do I need to purchase an upgrade license or can I just download the software and install it for free?
Marcos Hernandez Mon, 04/20/2009 - 11:54
  • Blue, 1500 points or more
Most SMARTNETS allow for software downloads, but you need to make sure that your contract allows for different feature sets. Send me a private email with your contract number and I will verify it for you.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
