Leo Laohoo Fri, 04/17/2009 - 21:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Any model. The appliance will be able to negotiate the duplex and speed settings to your machines Network Interface Card (NIC) whether it's 10, 100 or 1000 Gb. Just make sure it's not Novell. :)
Giuseppe Larosa Sat, 04/18/2009 - 01:59
  • Hall of Fame,
    Founding Member
Hello Indalacio,
if you mean what type of optical transceiver to use on the uplinks, the device can use SFP.
The exact type to use depends on what type is used at the other end of the fiber (two fibers) link.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/hardware/quick/guide/9368.pdf
chapter Connect to switch ports
for details about SFP modules see
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html
Hope to help
Giuseppe
