CME 7.1 to CCM 6.1
Answered Question
Apr 17th, 2009
Hi all i have tried to connect CCM to CME but it only works in one side : from CCM to CME it works well i can even hear my self in the other end however from CME to CCM i have a busy tone signal:
the following is my configuration setup:
On CallManager side: Sip trunk to the CME Ip Address, and then dial-peer on my voice gateway ( i use H323 to connect to the gateway) :
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
dial-peer voice 5000 voip
destination-pattern 5...
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.1.1
dtmf-relay sip-notify
no vad
dial-peer voice 2000 voip
destination-pattern 2...
voice-class codec 1
session target ipv4:192.168.2.211
dtmf-relay h245-alphanumeric
no vad
On CallManager Express side:
voice class codec 1
voice-class codec 1
no vad
telephony-service
em logout 0:0 0:0 0:0
max-ephones 4
max-dn 4
ip source-address 192.168.1.1 port 2000
max-conferences 12 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
PLZ note that from my CME on my router when i type in csim start 2008 (a phone registered with CCM) the phone ring and vise versa !:=)
I appreciate any help thanks
Correct Answer by Chris Deren about 8 years 1 week ago
I am assuming that 192.168.2.211 is the CM IP address.
Did you check to make sure that the CSS applied to the SIP trunk inculdes parition of the phone you are calling, also is the significant Digits setting set to All or 4?
What SIP security profile are you using? I would make sure it is not using Digest authentication.
Also, make sure you are binding sip to the correct interface on the router, the one with the IP address specified under the SIP trunk in CM.
You can also run "debug ccsip messages" and analyze the sip messages to look for reason for the failure.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Sat, 04/18/2009 - 05:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
Seifeddine-Tlili Sat, 04/18/2009 - 09:47
This is it :) i forgot to bind the SIP to my interface on my CCME :) thanks
