Static/Dynamic NAT at the same time
getahobby
I was just wondering if this setup would work:
global (External) 1 1.1.1.1
nat (Internal) 1 192.168.0.0 255.255.0.0
static (Internal,External) tcp 1.1.1.2 smtp 192.168.1.28 smtp netmask 255.255.255.255
In that setup we are doing static NAT/port forwarding for 1.1.1.2 to 192.168.1.28 in the inbound direction but on the outbound direction 192.168.1.28 gets NAT'd to 1.1.1.1. Is that possible?
andrew.prince
Level 10
Level 10
No - the static nat command works in both directions, so host 192.168.1.28 will be natt'd on the outbound to 1.1.1.2
HTH>
roshan.maskey
Yes, It will work.
ASA check NAT in following Priority
1. NAT Exemption
2. Static NAT/PAT (Regular and Policy)
3. Policy Dynamic NAT
4. Regular Dynamic NAT
Since your are doing Static PAT, and is bidirectional (1.1.1.2:25<->192.168.1.28:25).
And all application initiated by 192.168.1.2 will match Regular Dynamic NAT rule 1 and uses 1.1.1.1 as translated IP.
Note: if 192.168.1.28 is your email server and sends outbound smtp then it is recommended to do static NAT. Since your outbound smtp will be 192.168.1.28:35570->smtp.xyz.com:25 and will match IP 1.1.1.1
Some antispam engine using reverse dnslookup fails matching IP(dns record of smtp.yourdomain.com=1.1.1.2) and email received from yourdomain.com with sender ip 1.1.1.1, this mismatch might lead to as spam.
H2H
Roshan
AxiomConsulting
As I understand it (from your above config) you internal machine (192.168.1.28) will use the address 1.1.1.2 for all SMTP communications, all other communications will use the 1.1.1.1 address.
Steve
