RTMT - Linux - Blank Screen
I installed the RTMT on Ubuntu (2 different systems) and when I log in I get a popup to accept the security certificate(but the popup is blank, I know it is the cert because it does that on windows version of RTMT) The RTMT screen appears, but the java never loads so all I have is a grey screen. Anyone else have similar issues with RTMT on Linux?
vmoopeung Sun, 04/26/2009 - 17:50
  • Bronze, 100 points or more
Try to get a good copy of the ServicePathList.xml file and restart LPM and TLC services.
kseraphine Wed, 07/08/2009 - 09:05
I've had this issue with RTMT (and other java apps) under Linux with compiz enabled.
Under Ubuntu go to System->Preferences->Appearance and set Visual Effects to None.
Akin Utku Mon, 08/17/2009 - 22:12
Hey, can you help me install RTMT on Ubuntu? I have the 64bit kernel and the SUN 1.6 version of JVM. I get the below error when I try to install:
[email protected]:~/Documents$ ./CcmServRtmtPlugin.bin
Preparing to install...
Extracting the JRE from the installer archive...
Unpacking the JRE...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Exception in thread "main" java.lang.NoClassDefFoundError: com/zerog/lax/LAX
Caused by: java.lang.ClassNotFoundException: com.zerog.lax.LAX
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
Could not find the main class: com.zerog.lax.LAX. Program will exit.
[email protected]:~/Documents$ java -version
java version "1.6.0_14"
Java(TM) SE Runtime Environment (build 1.6.0_14-b08)
Java HotSpot(TM) 64-Bit Server VM (build 14.0-b16, mixed mode)
Akin Utku Mon, 08/17/2009 - 22:09
I can't even get the RTMT to install on Ubuntu. I get a Java error like:
Do you have the 64bit kernel? Any ideas?? If you can help me install, maybe I can help with the blank message problems hah.
joe.bennett Mon, 08/17/2009 - 23:01
Try turning off Compiz fusion. Go to system->preferences->appearance and on the effects tab select none. Works for me. - Whoops just seen earlier post mentions this -
