mls rate-limiting
Apr 18th, 2009
I'm wondering if you know how can I monitor, when I exceed the limits set by the mls rate-limiters in Catalyst 6500. Should I see something about that in a syslog?
Thanks in advance for any help
Giuseppe Larosa Sat, 04/18/2009 - 03:27
Hello Lukas,
I've found two sh commands
sh mls rate-limit
sh mls rate-limit usage
I don't know if these events are logged the objective is that of avoiding excessive cpu load and logging can loads the cpu as well.
in the above chapter there is a mention of logging when using a VACL
in the error message guide there is a section about MLS_RATE events but it include only related errors see
so no logging of activity without using the VACL if I've correctly understood.
Hope to help
lukaszkhalil Tue, 04/21/2009 - 23:15
Thank you. For sure logging could impact the CPU, but at least there should be a counter that can be readed, which shows that the mls limits are set to low.
I'll open a TAC case with such question. If I get any answer I'll let you know.
