Clients through Mesh AP are unable to get IP
Apr 18th, 2009
Dears
I am having 6 APs.Mesh is established and in all APs "Backhaul Client Access" is enabled.Problem is clients are able to get IP through Roof Top AP but not able to get ip from mesh AP.Is there noption i missed ? or any option i require to check or uncheck.
Please reply
Scott Fella Sat, 04/18/2009 - 08:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
So yoiu enabled "Backhaul Client Access" globally on the wlc. So now only 802.11a access will be allowed. So your clients are using 802.11a and not 802.11b/g correct?
asif.naveed Sat, 04/18/2009 - 10:41
Dear
I am sure you are right.But did we enable any client Acess as globally after mesh or keep it as default
Scott Fella Sat, 04/18/2009 - 11:22
  • Hall of Fame,
    2017 Wireless
If you leave it default then only 802.11bg will be used for client access, otherwise if enabled, only 802.11a will be used for client access.
asif.naveed Sat, 04/18/2009 - 11:28
But clients are not able to get IP address through MESH APs....but through RAP APs clients are able to get IP address
Scott Fella Sat, 04/18/2009 - 16:54
  • Hall of Fame,
    2017 Wireless
Do the client associate to 802.11a or 802.11b/g from the RAP?
