PRI Layer 2 lost connect to Carrier switch after MGCP apply from CCM
Apr 18th, 2009
I have Cisco 3845 router with T1 PRI from Verizon, " show isdn status " shows layer1 active and Layer 2 " MULTIPLE_FRAME_ESTABLISHED "
The ISDN layer2 change to " TEI_ASSIGNED" after applying MGCP from Callmanger ( Ver6.12) to 3845 Voice gateway. and both inbound and outbound call could not work.
Any advise.
Overall Rating: 5 (1 ratings)
Chris Deren Sat, 04/18/2009 - 17:01
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Please post your config as well as "sh ccm-manager".
Also, are you binding L3 to CM on the d-channel? You can validate this by making sure you have the following command under the serial interface corresponding to your PRI:
interface Serial0/0/0:23
isdn bind-l3 ccm-manager
HTH,
Chris
esa786_2 Sat, 04/18/2009 - 17:17
Hi.Since it is Layer 2, there is problem Between your router to privider switch. Pls check with the provider or
You can bounce the mgcp in the router
give command in the router
mgcp, no mgcp.
or shut , no shut the t1 controller.
will mostly solve the issue
regards
Esa
Kenneth Mohammed Sat, 04/18/2009 - 17:43
  • Silver, 250 points or more
I have seen this before as well, when layer 2 on the PRI will establish when in H323 mode, but when MGCP is applied,layer 2 wont establish. What I had to end up doing, is removing the QoS policy that was applied to the serial interface, and once layer 2 was established, I reapplied the QoS service policy.
Hope that helped, if so please rate.
