Call Block
Jaime Valencia Sat, 04/18/2009 - 14:51
  • Cisco Employee,
  • Hall of Fame,
    2011
create route patterns that match the specific mobiles you need to call
java
if this helps, please rate
esa786_2 Sat, 04/18/2009 - 16:16
Hi Jaime, Just creating a route pattern with the mobile of supervisor is enough, or we have to do some other configuratin. pls give the full config info.
Esa
Jaime Valencia Sun, 04/19/2009 - 09:12
  • Cisco Employee,
  • Hall of Fame,
    2011
create dial-peers that match the exact mobiles you need to call, same thing just using CME terminology
java
Hi, created the dp but this doen not work. The block pattern looks for the 0, and the mobile number starts with 0.
here is my config:
after-hours block pattern 1 0
dial-peer voice 200 pots
description Test block override
destination-pattern 0824476951
port 0/0/0:15
any ideas ?
