How to enable IPS IPS/IDS in cisco 2811
Apr 19th, 2009
Hi all,
I have a Cisco 2811 with IOS Version 12.4(20)T and I need to enable IPS or IDS in this. What is the config for this?
First of all, I need to know whether I can do IPS/IDS in my router as well..
- Ribin
roshan.maskey Sun, 04/19/2009 - 03:12
Hi Ribin,
Cisco Router supports IOS IPS 5.x.
The following is the sample configuration:
Step 1: Verify if you have signature file (128MB.sdf or 256MB.sdf)
router# sh flash
Step2: Specify router to use sig-definition file
router(config)# ip ips sdf location flash://128MB.sdf
Step3: create signature_rule
router(config)# ip ips name myips_rule
Step4: Apply IPS rule to interface
router(config)# interface fa0/0
router(config-if)# ip ips myips_rule in
Step5: Enable IPS SDEE notification
router(config)# ip ips notify sdee
You can further tune IPS signature using SDM
H2H
Roshan
ribin.jones Sun, 04/19/2009 - 03:38
I don't have 128MB.sdf or 256MB.sdf. But I do have a attack-drop.sdf. Any idea what it might be?
ribin.jones Sun, 04/19/2009 - 03:51
hi,
Also, I see the below from my config prompt
Router(config)#ip ips ?
auto-update Auto Update
config Location of IPS configuration files
deny-action Specify Deny action
event-action-rules Event Action Rules (SEAP)
fail Specify what to do during any failures
name Specify an IPS rule
notify Specify the notification mechanisms (SDEE or log) for
the alarms
signature-category Signature Category
signature-definition Signature Definition
I don't see
ips sdf command.
roshan.maskey Sun, 04/19/2009 - 04:05
Hi Ribin,
attack-drop.sdf is the basic signature file. You need to download 128MB.sdf or 256MB.sdf, which is also in SDM disk.
"ip ips sdf location " command is for 18XX router
use the following command for 28xx
ip ips config location flash://128MB.sdf
H2H
Roshan
ribin.jones Sun, 04/19/2009 - 04:47
I did enabled IPS in the router and configured to notify to our log server. Below is the log I received in my log server.
What does IPS does now and what kind of logs I can expect?
Ribin
Apr 19 14:53:38 192.168.11.10 4546: *Apr 19 09:27:41.254: %SYS-5-CONFIG_I: Configured from console by ribin on vty0 (192.168.11.35)
Apr 19 18:04:29 192.168.11.10 4548: *Apr 19 12:38:32.601: %CRYPTO-6-IPSEC_USING_DEFAULT: IPSec is using default transforms
Apr 19 18:12:10 192.168.11.10 4549: *Apr 19 12:46:14.541: %IPS-6-ENGINE_BUILDS_STARTED: 12:46:14 UTC Apr 19 2009
Apr 19 18:12:10 192.168.11.10 4550: *Apr 19 12:46:14.541: %IPS-6-ENGINE_BUILDING: atomic-ip - 3 signatures - 1 of 13 engines
Apr 19 18:12:10 192.168.11.10 4551: *Apr 19 12:46:14.557: %IPS-6-ENGINE_READY: atomic-ip - build time 16 ms - packets for this engine will be scanned
Apr 19 18:12:10 192.168.11.10 4552: *Apr 19 12:46:14.557: %IPS-6-ALL_ENGINE_BUILDS_COMPLETE: elapsed time 16 ms
ribin.jones Sun, 04/19/2009 - 06:06
hi,
Also I see the following error in my log server:
%IPS-3-IPS_FILE_OPEN_ERROR: flash://128MB.sdf/Router11.10-seap-typedef.xml - Requested operation requires a directory
bstiff Wed, 05/06/2009 - 13:16
The recommendation to use the 128MB.sdf or 256MB.sdf is not correct for the version of software that you're using. IOS 12.4(11)T and later use the v5 signatures, available here:
http://www.cisco.com/cgi-bin/tablebuild.pl/ios-v5sigup
There is a video demonstration describing the use of Cisco Configuration Professional for IPS, here:
http://www.cisco.com/cdc_content_elements/flash/ios/configios/index.html
The CLI configuration guide is here:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/ips_v5.html
Be sure that you configure the IPS to load the 'ios_ips basic' or 'ios_ips advanced' categories. If the router tries to load the default signatures, it will run out of memory and crash.
