Ether-Channel Frequent problem
Apr 19th, 2009
Hii Freinds,
Facing some strange problem with Ether-Channel. We have two cisco 4507 switches placed remote to each other (i.e not at same place), connected with two parallel simataneous links(on gig ports) on which L2 etherchannel is running.
When there is problem with any of the link, remote end (i.e Switch-2 ) unreachable and always we have to manually shut first link port from Switch-1 ... then after reachability of switch-2 is fine on another/second link.
Second case, In case of unreachability os switch-2, When we only shut second link port from Switch-1 end. Switch-2 is not getting reachable i.e Switch-2 unreachable.
We have checked for solution in all way. But still have to find out the root cause, Whether problem is happening due to issue from transmission end or due to our switches configs(etherchannel/ port channel related).
Configs of ether-channel from both the Switches are as:-
Switch-1 EtherChannel Config :-
Cisco_4507_Sw1#sh run int po1
Building configuration...
Current configuration : 269 bytes
interface Port-channel1
switchport
switchport trunk allowed vlan 2,4,6,8,10,12,14
switchport mode trunk
switchport nonegotiate
speed nonegotiate
end
Cisco_4507_Sw1#sh run int gi1/2
Current configuration : 371 bytes
interface GigabitEthernet1/2
description ++ GigaLink 4507 on Switch-2 Corresponding port Gigi1/4 ++
speed nonegotiate
channel-group 1 mode on
end
Cisco_4507_Sw1#sh run int gi1/3
Current configuration : 370 bytes
interface GigabitEthernet1/3
description ++ GigaLink 4507 on Switch-2 Corresponding port Gigi1/5 ++
speed nonegotiate
end
Ether-Channel config on Switch-2 :-
Cisco_4507_Sw2#sh run int po1
switchport
speed nonegotiate
end
Cisco_4507_Sw2#sh run int gi1/4
Current configuration : 356 bytes
interface GigabitEthernet1/4
description ++ Gig Connectivity on Switch-1 corresponding port Gigi1/2 ++
speed nonegotiate
end
Cisco_4507_Sw2#sh run int gi1/5
interface GigabitEthernet1/5
description ++ Gig Connectivity on Switch-1 corresponding port Gigi1/3 ++
speed nonegotiate
end
Please help to diagnose the reason of problem.
Network snerio attached here.
regards
Giuseppe Larosa Sun, 04/19/2009 - 03:39
  • Hall of Fame,
    Founding Member
Hello Jimmy,
if the transport MUXs are able to keep the interface up/up you should use LACP:
lacp provide signalling messages that are exchanged every few seconds
try to do the following on both ends
int gix/y
channel-group 1 mode active
in this way the remote switch should be able to detect when a link is seen as not working : it stops to receive LACP messages and so it can disable the link.
Hope to help
Giuseppe
cisco.net Sun, 04/19/2009 - 08:40
Hiii Giuseppe,
Seems you are almost close and very right that in all condition / always Gig ports at both the switches are UP even when fiber link between both the MUXes went down then also ports are reflecting as UP only.
But ideally if problem happen in any of the link, then respective ports should go down at both switches.
So..."channel-group 1 mode active" command is only for this purpose...? is this command will do the same thing which UDLD feature is doing..? I am putting this concern just b'coz i have also checked by enable "udld port aggresive" in respective port-channel bundled Gig interfaces at both switches, but problem was as it is.
Jimmy.
Giuseppe Larosa Sun, 04/19/2009 - 11:09
  • Hall of Fame,
    Founding Member
Hello Jimmy,
UDLD is for detecting uni-directional links.
LACP is a protocol designed for negotiating, setting up and to dynamically adjust/mantain etherchannels and it is standards based
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swethchl.html#wpxref12539
Hope to help
Giuseppe
cisco.net Mon, 04/20/2009 - 01:07
HI Giuseppe ,
Oe more observation found.
very Few access nodes(lets say 2 nodes out of 10) which are connected from Switch-2 are going unreachable while shutting first link. rest nodes are reachable fine.
On shutting second link, as mentioned in first updates Switch-2 totally unreachable for us but the same sites connected from switch-2 which are unreachable while shutting first links are now reachable. just amazing. what could be the reason.
Giuseppe Larosa Mon, 04/20/2009 - 01:33
  • Hall of Fame,
    Founding Member
Hello Jimmy,
from the point of view of the bundle each telnet session is a flow.
Each flow is associated with one member link.
Flows associated to the link that actually is not working are sent to a black hole.
This is the reason you see some switches behind the bundle unreachable and other reachable.
And it is for this kind of problems that I suggest to move to an LACP managed bundle.
Hope to help
Giuseppe
cisco.net Mon, 04/20/2009 - 03:09
Is same thing also happening with PING..?? (as you mentioned above for telnet session).
regards
Giuseppe Larosa Mon, 04/20/2009 - 04:04
  • Hall of Fame,
    Founding Member
Hello Jimmy,
yes traffic flows are defined by IP SA and IP DA for etherchannel load-balancing purposes so it doesn't change with ICMP or with TCP port 23 (telnet)
Hope to help
Giuseppe
cisco.net Mon, 04/20/2009 - 09:26
Hii Giuseppe,
I have tryed you suggestion i.e configured "channel-group 1 mode active" on switch-1 and switch-2 Gig ports, But again after that Switch-2 was totally un-reachable.
Hence when i tryed to revert the config mode active command was removed but now all Gig ports are not taking old command "channel-group 1 mode on". We were in trouble. traffic only follwing path of 1st link.
However we removed command "mode active" from all ports. But still etherchannel is showing LACP protocol.
Cisco_4507_Sw1#sh etherchannel 1 summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi1/2(P) Gi1/3(P)
ISP#
PLease help to revert disable the LACP for which we tryed all command but the same is not removing.
