Deployment problem!
agipkcolon
CW3.1
I could successfully run compliance check. I needed all switches to have bpduguard disabled on fa ports.
When I start deployment for any of my 3750 switch RME successfully changes 14-15 first ports and then I can see my RME account being idle on switch for 20 minutes. then it exits.. but my jobs in RME are still in status "Running". So configuration is not finished. I can't stop the jobs and all I can do is to restart server.
please I need help on this issue urgently.
7 Replies 7
Joe Clarke
What protocol are you using to deploy the commands to the devices?
it is ssh.
You are most likely seeing CSCsx24218, then. A patch is available by contacting the TAC.
is there any way to get the patch if we don't have service contract? I can't register TAC and trying to find information for contract number
No. This patch is currently only available from TAC.
thank you,
will try to find contract number
it is ssh.
