2800 router and 3750 switch won't create gigabit trunk
Answered Question
Apr 19th, 2009
Hi there Tech-xperts,
I have a 2800 router and 3750 switch that will not operate at Gigabit speed. I've tried various combinations of fixed/auto speed and duplex settings, but they only seem to talk to each other when set to 100Mb.
Any fixes or suggestion greatly appreciated.
2821 router 12.4(20)T1
3750 switch Version 12.2(25)FZ
(3750 is actually a WS-C3750G-24WS-S25)
These are directly connected via a UTP cable.
The router interface config:
interface GigabitEthernet0/1
no ip address
duplex full
speed 100
interface GigabitEthernet0/1.500
encapsulation dot1Q 500 native
ip address 10.10.150.1 255.255.255.0
interface GigabitEthernet0/1.520
encapsulation dot1Q 520
ip address 10.10.120.1 255.255.255.0
interface GigabitEthernet0/1.521
encapsulation dot1Q 521
ip address 10.10.121.1 255.255.255.0
The switch interface config:
interface GigabitEthernet1/0/1
description rtr INMRTR01 via Riverbed
power inline never
switchport trunk native vlan 500
switchport mode trunk
duplex full
spanning-tree portfast
Correct Answer by glen.grant about 7 years 10 months ago
I would say you have a faulty patch cable if it won't negotiate gig speed with both sides as auto. Gigabit uses all 8 wires to achieve gig whereas it uses 1,2,3,6 for any lower speeds . So if you don't have 8 good wires in your patch cable or connection between these 2 devices you won't get gig speed.
Overall Rating: 5 (1 ratings)
Correct Answer
glen.grant Sun, 04/19/2009 - 09:31
theroofisonfire Mon, 04/20/2009 - 22:25
Thank Glen,
New cable fixed it. Surprisingly the existing 1/2 meter cable tests ok with my (basic) cable tester.
Roof
