ARC Console
Apr 19th, 2009
Hi there,
My customer is using ARC Console version 4.1.3 with CCM 4.2.3.
Now the customer is going to upgrade the CCM from 4.2.3 to 6.1.3. We have done following steps in the ARC console but failed, please advise.
1. Uninstall the old TSP driver
2. Install new TSP driver from CCM 6.1.3
Result:
The corresponding CTI route point and CTI ports do not successfully registered with CCM 6.1.3.
May I ask for your help how to fix this problem?
thanks a lot
David
Ayodeji Okanlawon Sun, 04/19/2009 - 06:03
  • Cisco Designated VIP,
    2017 IP Telephony
Have you checked the CTI user name and password in your TSP configuration on the ARC server. In CCm4.2.3 the user is usually an application user, in CCM6.X the user should be an end user...You then need to assign the user to a user group that has the roles for all the CTI options.
i.e assign a user group to the user and then assign roles to the user group with all the Cisco Computer Telephony Interface (CTI) options. Make sure all your ARC devices are associated with this user
dconstantino Sun, 04/19/2009 - 18:47
If you are syncing with AD through LDAP you can not add users. So do you have the add a user in AD let it sync with CUCM and then add the CTI ports to it.
dhcchan Sun, 04/19/2009 - 22:23
Hi there,
yes, i have tried to create an application user and all CTI groups selected, but still fail.
So may I ask for your idea how to fix it?
thanks a lot
David
Ayodeji Okanlawon Mon, 04/20/2009 - 05:19
    2017 IP Telephony
I said you should use an end user..not application user....
dhcchan Mon, 04/20/2009 - 06:54
Hi there,
I have tried both "end user" and "application user" but fail at both case :<
thanks a lot
David
Ayodeji Okanlawon Mon, 04/20/2009 - 08:15
    2017 IP Telephony
You can do two things
1. Uninstall the TSP and re-install it
on the Arc server.
2. Install the wave driver
3. Configure the tsp. make sure you specify the number of voice lines to be more than 1. The max is 255, you can use 250
The try again.
If it still does not work, you will need to get set TSP tracing configuration on the ARC server to detailed/debug and then look at the logs to see what is happening
