SPA400 problems
srice81166 Mon, 04/20/2009 - 07:47
You can download SoftPerfect Network Scanner and run it. It will show you the mac address's and IP. Just put in the ip range of the network and find the mac. It is a free program just google it. Hope this helps.
mzokov_vit Wed, 04/22/2009 - 05:28
To reset the SPA9000 you will need to:
1. Plug an analog phone into Port 1 and use IVS.
2. Enter ****
3. From the analog phone enter 73738#.
4. Press 1 to confirm or * (star) to cancel. This feature may be protected by a password.
5. System will request confirmation; enter 1 to confirm. You will hear, “Option successful.”
6. Hang up the phone. The System will reboot, and all settings will be reset to their factory default settings
After that IP at the SPA9000 will be set to factory-default 192.168.0.1
By default, the SPA400 is configured to obtain an IP Address via DHCP. You can check the obtained IP address on the router DHCP server's client list.
If you can't do this just factory reset the unit by pressing the Reset button for 10 seconds. Default web-pass is "Admin" with no pass.
