VPN with Transparent firewalls
Apr 19th, 2009
I need comments about the following:
I have a WAN network installed using Leased Lines and the addressing is done. Now I want to implement ASA on each site for VPN. And to keep the addressing schema, I'll use ASA as transparent firewalls.
Any comment about the solution ?
Omar
