04-19-2009 08:09 AM - edited 03-06-2019 05:15 AM
I had a switch go down recently. In replacing said switch i dropped the config onto the replacement, copied running config to start and reloaded.
However, when it had booted back up, i was unable to connect back onto the switch via the console cable.
Its simply states that Con0 is now available, press return to get started. However when i hit return it flashes Authentication failed and then loops back to Con0 is now available, press return to get started.
Can anybody offer me advice on
a)what could be a possible cause of this and
b) how i could resolve the problem.
Thanks in advance
Lee
04-19-2009 11:03 AM
I am new to this, but I think the issue might be you might be attempting to have your sw attempt to reach a radius or tacacs for auth (bad for a local console port). You need to set it for local atuh (I believe its 'login local'). I could be totally wrong in my observation though.
To fix it boot your sw (if you have that luxury)...I followed this guide, http://www.petri.co.il/csc_how_to_recover_lost_password_on_cisco_switch.htm, but you can find something on ciscos site also, and change/observe your line con 0 config that way.
Cheers
Jimmy
04-19-2009 11:39 AM
Thanks Jimmy
I'll give that a try and feedback.
Thanks again
Lee
04-20-2009 06:30 AM
If you are able to reboot the switch I would do the following:
reboot the switch
press on the mode button in order to come in rommon mode
switch: flash_init
switch: rename flash:config.text flash.config.text.temp
switch:boot
The switch will boot without any configuration because it can't find config.text.
Answer 'no' for initial configuration
switch>en
switch#copy flash:config.text.temp run
switch#wr
and then you've to look what's configured
aaa new-model
aaa authentication login default local
or
line con 0
login local
if this is true> check if there is a
user xxx secret/password xxxx is configured
I suspect that no user x secret xxx is configured.
Else you can help by posting all related config
