!!! WARNING: The switch is not usable !!!
Apr 19th, 2009
Hi, I have a 3560 switch.
I kept getting this message, " !!! WARNING: The switch is not usable !!!
what should I do? How do I have it fixed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
HTD POST: Basic Test Failed
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
Unable to create l2trace server process, socket_open() failed
Press RETURN to get started!
Thank you for your help
glen.grant Sun, 04/19/2009 - 09:26
  • Purple, 4500 points or more
Its what it says , its a HW issue . Call cisco and get it rma'd.
nguyenjitsu Sun, 04/19/2009 - 10:00
Thank you for your reply, I don't have the warranty on this switch. What is the ballpark for this repair, thanks!
glen.grant Mon, 04/20/2009 - 03:57
Call cisco think this has a lifetime warranty and a 3560 is not that old of a model. You will need the serial number off the switch.
Jacob Zartmann Thu, 11/10/2011 - 10:13
I have the same issue on a WS-C3550-24-PWR in my lab. Reports:
POST: CAM Subsystem Tests : Begin
Address bus test failed for associated data
POST: CAM Subsystem Tests : End, Status Failed
INIT: failed CAM ASIC initialization
And shortly after this:
Reason:
Did you ever get Cisco to replace the switch or? This one is way out of warranty, but if a switch has a lifetime warranty of this failure then I'm glad
Could be nice to be able to do some labs at home.
Thanks.
/JZ
Leo Laohoo Thu, 11/10/2011 - 13:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
3550 is not covered under the new Extended Lifetime Warranty.
Stefan Timuta Wed, 03/29/2017 - 01:59
Hi, I know it's been 8 years but may be it would be useful for others, just change the IOS from ROMMON Mode.
