VPN lab help
Apr 19th, 2009
What extra would I need to practise creating VPN's in a lab at work rather that on the live equipment?
All I have is a Pix 515, 2 switches a 2950 and a 3550, and a couple of 2620 routers which have 2 WIC cards in each, but only 1 FE on each.
If this enough equipment to practise VPN's what would I need to use to achieve this etc?
Jon Marshall Sun, 04/19/2009 - 11:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
If you have a 2620 then you should be able to create an IPSEC site-to-site VPN between the 2620 and the pix. You would need the right feature set on the 2620 - have a look at Feature Navigator for the right IOS version.
Jon
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Deleted - posted twice.
Jon
