Port-Channel
vishwancc
Level 3
Level 3
Hi All,
I am facing a very strange issue with my port-channel port.
The port is going down due to some reason and then coming back up.
There are no error on the port interface and i have already changed the port physically to different one.
This is the only port in the port channel which is having this issue.
And yes i have 5 ports in my port-channel bundle.
There is one more thing the vlan allowed on the ends are different ,but as i said out of 5 ports with same configuration only 1 is having this issue rest all the working fine.
interface FastEthernet4/4
switchport trunk allowed vlan x,x,x,x
switchport mode trunk
logging event link-status
speed 100
duplex full
channel-group 1 mode active
FastEthernet4/4 is up, line protocol is up (connected)
Hardware is Fast Ethernet Port, address is 0017.593a.8123 (bia 0017.593a.8123)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 192/255, rxload 65/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, link type is auto, media type is 10/100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input 00:00:15, output never, output hang never
Last clearing of "show interface" counters 1d03h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 28097
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 25730000 bits/sec, 10540 packets/sec
5 minute output rate 75673000 bits/sec, 11408 packets/sec
719728814 packets input, 231640805874 bytes, 0 no buffer
Received 90645 broadcasts (6995 multicast)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
757223878 packets output, 590713356235 bytes, 0 underruns
0 lost carrier, 0 no carrier
.Apr 17 15:47:15.710 GMT: %EC-5-UNBUNDLE: Interface Fa4/4 left the port-channel Po1
: .Apr 17 15:47:16.754 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4/4, changed state to down
: .Apr 17 15:47:17.710 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to down
: .Apr 17 15:47:20.846 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to up
: .Apr 17 15:47:30.090 GMT: %EC-5-L3DONTBNDL2: Fa4/4 suspended: LACP currently not enabled on the remote port.
: .Apr 17 15:47:37.866 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to down
: .Apr 17 15:47:41.846 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to up
: .Apr 17 15:47:44.874 GMT: %EC-5-BUNDLE: Interface Fa4/4 joined port-channel Po1
: .Apr 17 15:47:45.914 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4/4, changed state to up
: .Apr 17 15:51:37.101 GMT: %EC-5-UNBUNDLE: Interface Fa4/4 left the port-channel Po1
: .Apr 17 15:51:38.121 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4/4, changed state to down
: .Apr 17 15:51:39.101 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to down
: .Apr 17 15:51:41.840 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to up
: .Apr 17 15:51:50.948 GMT: %EC-5-L3DONTBNDL2: Fa4/4 suspended: LACP currently not enabled on the remote port.
: .Apr 17 15:51:56.512 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to down
: .Apr 17 15:52:00.840 GMT: %LINK-3-UPDOWN: Interface FastEthernet4/4, changed state to up
: .Apr 17 15:52:03.884 GMT: %EC-5-BUNDLE: Interface Fa4/4 joined port-channel Po1
: .Apr 17 15:52:04.900 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4/4, changed state to up
Chao
Vishwa
mahmoodmkl
Level 7
Level 7
HI
why u have placed the above line under the interface,is it applied to all interfaces or not..?
if u make the port channel as active then it will enable LACP rather Pagp.
The allowed range should be same on both ends ie on both the switches.
And i see that u trying to use LACP make sure that u have it configured on the other end.
Mahmood
Hi Mahmood,
I want to run LACP only,as i have said i dont see any problem in the configuration since this port channel have 5 port out which only 1 is creating problem,if its the issue with configuration i would face this with all the ports.
Chao
Vishwa
Giuseppe Larosa
Hello Vishwa,
According to your log this port didn't hear LACP messages coming from the remote end:
Verify if the other side is the right expected port.
Someone suggests for avoiding timing issues to use an interface range macro to enable all the ports at once when using LACP.
Hope to help
Giuseppe
Hi Giuspee,
If you see the port is first going down and then coming up and then the LCAP message,after that it joins the port channel again.
It dont seems to me the issue with LCAP.
these port channel are part of my oc3 link to ISP,incase this helps.
Chao
Vishwa
