Script to Shut and Unshut a Port on a Periodic Manner
Apr 19th, 2009
Hi Guys, Our client requires that a certain port on a 3560 switch be shutdown at 7pm and unshut at 7am. What is the best solution for their requirements, is an EEM script capable of doing the trick? Please help.
Joe Clarke Sun, 04/19/2009 - 22:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
EEM is certainly a possibility. What version of IOS is running on this switch?
renato.berana Mon, 04/20/2009 - 00:28
The switch is running ip-services 12.2(50)SE1. How to do that using EEM?
Joe Clarke Mon, 04/20/2009 - 06:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These two applet policies should do what you want:
event manager applet shut-port
event timer cron cron-entry "0 19 * * *"
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "int $port_to_shut"
action 4.0 cli command "shut"
action 5.0 cli command "end"
action 6.0 syslog msg "Successfully shutdown $port_to_shut"
event manager applet no-shut-port
event timer cron cron-entry "0 7 * * *"
action 4.0 cli command "no shut"
action 6.0 syslog msg "Successfully brought $port_to_shut back up"
Then, just set the port_to_shut environment variable to the value of the port you want to shutdown. For example:
event manager environment port_to_shut Fa0/5
