Compatibility between 4503-E and GLC-SX-MM= SFP module
Apr 19th, 2009
can anyone tell me if these two a compatible, the supervisor on 4503 is
Supervisor Engine II-Plus-TS 12 10/100/1000 Mbit POE+ plus 8 SFP
I've found in the documentation that the supervisor is compatible with GLC-SC-MM-Gigabit Ethernet SFP, LC connector, SX transceiver
I found only this one in the Cisco configurtor
GLC-SX-MM= GE SFP, LC connector SX transceiver
The difference is between SX and SC
Overall Rating: 5 (2 ratings)
Marvin Rhoads Mon, 04/20/2009 - 05:07
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
I'm wondering if it's a documentation typo on the 4503 product information sheets. That's the only place on all of Cisco.com that I see any reference to the "GLC-SC-MM" part. It is described using the same terms as the "GLC-SX-MM".
Further, the overall transceiver module installation notes does not list the "GLC-SC-MM". See http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/installation/note/78_15160.html
Tom Randstrom Mon, 04/20/2009 - 05:50
  • Gold, 750 points or more
I agree with "mklemovitch"; the reference to the "GLC-SC-MM" in the documentation is in error. The correct part number should be "GLC-SX-MM" as per the compatibility and SFP data sheets.
I have sent feedback to the Cisco.com outlining the error to get it corrected.
Marvin Rhoads Mon, 04/20/2009 - 06:00
Oh - also note that the letter "x" is next to the lettter "c" on a standard keyboard! ;)
smailmilak83 Mon, 04/20/2009 - 06:00
Thank you guys.
I used the Dynamic Cisco configuration tool and I found there the GLC-SX-MM.
It is all okey now.
