Catalyst 4503-E SFP compatibility
Apr 20th, 2009
I found out that the 4503 with Supervisor Engine II-Plus-TS supports the GLC-SC-MM SFP module. The problem is that I can't find it, looks like Cisco is not selling it anymore.
I found only this: GLC-SX-MM=
I the Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
(http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp130094)
it says that this SFP is only compatible with 4506 and others, not 4503.
What SFP module could I use on the 4503 and 2960 for Multimode fiber?
Giuseppe Larosa Mon, 04/20/2009 - 01:04
  • Hall of Fame,
    Founding Member
Hello Smail,
usually a = is added to replacement parts or as stand-alone products it should be the same SFP you are looking for
GLC-SX-MM=
1000BASE-SX SFP transceiver module for MMF, 850-nm wavelength
About devices: the table should discriminate about the type of supervisors for thr 4500 not the chassis model.
You should be fine.
Hope to help
Giuseppe
smailmilak83 Mon, 04/20/2009 - 01:14
The = is not a problem.
The problem is between these two SFPs
One is GLC-SC-MM and the other GLC-SX-MM
the difference is between SC and SX.
And that is that is causing me problems. I have to be sure that I order the right SFP for the Supervisor EngineII-Plus-TS
and 2960 TC-L and 2960 PC-L.
Leo Laohoo Mon, 04/20/2009 - 14:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
GLC-SC-MM (Gigabit Ethernet SFP, LC connector, SX transceiver) is for the 4500 Series Supervisor Engine II-Plus-TS. Have you tried inserting a GLC-SX-MM in to see if it will work?
smailmilak83 Mon, 04/20/2009 - 22:15
Yeah I found it in the Dynamic Configuration Tool, so it is officially supported.
