Reset password on Cisco 2100 Wireless LAN controller
Answered Question
Apr 20th, 2009
My company has been using a Cisco 2100 Wireless LAN controller for about two years, without any problems. I'd now like to change the configuration, but nobody knows the password (which has changed from the default of 'admin').
I understand there isn't a way I can reset the password, even using the console cable. How can I find out the factory password? The details of the unit are:
S/N: JMX1135K001
MAC: 00070e25bd60
Embedded BIOS version 1.0(12)6
The device is out of warranty and not under a service contract, which is why I'm posting on this forum.
Many thanks in advance,
Tim Styles
Correct Answer by Leo Laohoo about 8 years 6 days ago
Hi Tim,
Scott's right. Also, there's no "password recovery" for the WLC. The only way is to reset the appliance into factory default.
Hope you backed up your config.
Hmmm ... If you do backed up the config, search for the encrypted password. Create a TAC and pray that they will use their password decrypter.
Correct Answer by Scott Fella about 8 years 1 week ago
Tim,
There is no default username and password. These are created when you enter the startup configuration wizard. If you have documentation about the wireless, you might be able to just delete the configuration and start all over again. If you have snmp and you know the snmp strings, you might be able to get some of the wlc information.
Overall Rating: 4 (2 ratings)
Correct Answer
Scott Fella Mon, 04/20/2009 - 04:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Tim,
Correct Answer
Leo Laohoo Mon, 04/20/2009 - 14:49
  • Hall of Fame,
    2017 LAN, Wireless
Hi Tim,
timstyles Tue, 04/21/2009 - 06:27
Thanks for the replies leolaohoo and fella5.
I had been reading the quick start guide here:
http://www.cisco.com/en/US/docs/wireless/controller/2100/quick/guide/ctrl206q.html
and it implied that resetting the unit would still require me to enter a username and password.
When I tried it I saw the message about entering 'Recover-Config' for the username, and then I reconfigured the controller with a new user name and password. The quick start guide also mentions the default values of 'admin' if a username and password are not entered.
Thanks for pointing out that a reset is all that's required to enter a new username and password.
Leo Laohoo Tue, 04/21/2009 - 13:50
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
