PLATFORM_UCAST-6-PREFIX error
Answered Question
Apr 20th, 2009
a 3750 have this problem:
tech note
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(50)SE1,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 06-Apr-09 08:19 by amvarma
Image text-base: 0x00003000, data-base: 0x01D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE
(fc1)
in the log there is this problem:
*Mar 1 12:38:14: %PLATFORM_UCAST-6-PREFIX: One or more, more specific prefixes
could not be programmed into TCAM and are being covered by a less specific pref
ix
if i wiev the explain of this error in cisco.com tell this:
Error Message PLATFORM_UCAST-6-PREFIX: One or more, more specific prefixes could not
be programmed into TCAM and are being covered by a less specific prefix
Explanation A more specific prefix could not be programmed into Ternary Content Addressable Memory (TCAM) and is covered by a less specific prefix. This could be a temporary condition. The output of the show platform ip unicast failed route privileged EXEC command lists the failed prefixes.
Recommended Action No action is required.
But , how can i to do for to remove this error or warning from the log?
thanks for yuor help
fcostalunga
Correct Answer by Giuseppe Larosa about 7 years 10 months ago
Hello Francesco,
the 6 is for the severity level of the log message if you don't use ipv6 the routing sdm can be the right choice for use.
Hope to help
Giuseppe
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Mon, 04/20/2009 - 04:02
Hello Francesco,
you may need to change the SDM template that decides how the TCAM resources are used.
see
sdm prefer {default | dual-ipv4-and-ipv6 {default} | qos}
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_40_se/configuration/guide/swsdm.html
you may need to use a template more router oriented like dual-ipv4-and-ipv6 if you use IPv6
if you decide to change the SDM template you need to save the config and then to reload.
Hope to help
Giuseppe
Correct Answer
Giuseppe Larosa Mon, 04/20/2009 - 10:39
Hello Francesco,
Hope to help
Giuseppe
