CUCM and CUBE with SIP Trunk
Apr 20th, 2009
I am currently trying to migrate from a CUCME system to a CUCMBE using a SIP trunk for PSTN access. I have been using CUCME for the SIP trunk for some time but am now trying to configure the CUCMBE using a CUBE which I have read is best practise. I have the CUBE configured for switch over which I intend to do in the next couple of days and have configured the a SIP trunk already from the CUCMBE to the CUBE however I am not seeing any output from the show commands to indicate this is working. Is there anything I can test or view on either the CUBE or CUMBE to indicate the SIP trunk is working prior to the PSTN switchover
Michael Owuor Mon, 04/20/2009 - 04:40
Hi Ian,
Do you have the option of creating a test route pattern that specifically directs a call to the CUBE?
ianwarb Mon, 04/20/2009 - 23:48
I have a DDI range I can use but after testing this the SIP trunk is not coming up so I cannot get to the PSTN. How can I test the CUBE to CUCM element
mcinu4cco Fri, 04/24/2009 - 04:09
You can make route pattern pointing to CUBE with some prefix and numbers let's say 9.XXX.
Then you can debug voice dialpeer or debug ccsip messages. Then place a test call 9xxx from ip phone and see debugging messages.
Does your SIP trunk to provider has to be registered or unregistered? Can you show your configuration to provider?
