Collin Clark Mon, 04/20/2009 - 05:18
  • Purple, 4500 points or more
Switch#
Switch#config terminal
Switch(config)#interface vlan 1
Switch(config-int)#ip address 192.168.1.5 255.255.255.0
I'm assuming your changing VLAN1's IP, so if you use a different one for management, go to that interface. Once you hit enter the change takes place immediately. You will then need to connect to the new address and save the config. You may also have to change the ip default-gateway. It's best to make these changes from the console.
Hope that helps.
Leo Laohoo Tue, 04/23/2013 - 14:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes you can.  Just cut-and-replace what you have (IP Address) with the example Collin has posted.
InayathUlla Sharieff Tue, 04/23/2013 - 20:26
  • Cisco Employee,
Easy one for me.
Switch#
Switch(config-int)#ip address 192.168.1.3 255.255.255.0
Inayath
