web login failed on cue
Answered Question
Apr 20th, 2009
dears,
i am trying to initialize cisco unity express to connect it to call manager express, but when i enter to configure callManager. and enter the web username and password and JTAPI user the following is displayed:
saved successful
web login failed. Error while determining CCM version -1
JTAPI login failed. Error while determining CCM version -1
can anyone help??
Correct Answer by Rob Huffman about 8 years 2 months ago
Hi Moustpha,
Yes, this should show (when integrating with CME);
Application mode: CME or CCME
You can download the proper license for CME from the page I linked on the first post :)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 04/20/2009 - 04:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Moustapha,
Here are some examples of where I think this went wrong. You may be trying to use the wrong License file;
For Callmanager (which I think you have used)
cue-vm-license_12mbx_ccm_3.0.2.pkg
License information package for a 12-mailbox version of the Cisco Unity Express with VoiceMail application that works with Cisco Unified CallManager. For all Cisco Unity Express modules: AIM-CUE, NM-CUE, NM-CUE-EC & NME-CUE.
For Callmanager Express - CME (which I think you need)
cue-vm-license_12mbx_cme_3.0.2.pkg
License information package for a 12-mailbox version of the Cisco Unity Express with VoiceMail application that works with Cisco Unified CallManager Express. For all Cisco Unity Express modules: AIM-CUE, NM-CUE, NM-CUE-EC & NME-CUE
From this link;
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-302-licenses
Hope this helps!
Rob
Mustafa Al Housami Mon, 04/20/2009 - 05:02
Hi Rob,
I have the following licenses:
CUE#sh software licenses
Installed license files:
- voicemail_lic.sig : ENGINEERING 12 MAILBOX LICENSE
Core:
- Application mode: CCM
- Total usable system ports: 6
Voicemail/Auto Attendant:
- Max system mailbox capacity time: 840
- Default # of general delivery mailboxes: 5
- Default # of personal mailboxes: 12
- Max # of configurable mailboxes: 17
Interactive Voice Response:
- Max # of IVR sessions: Not Available
Languages:
- Max installed languages: 1
- Max enabled languages: 1
Does this line "Application mode: CCM" means that i have the wrong license.
If not how can i check which license file am i using?
Your reply is really appreciated
Correct Answer
Rob Huffman Mon, 04/20/2009 - 05:12
  • Hall of Fame,
    Founding Member
Hi Moustpha,
Hope this helps!
Rob
Mustafa Al Housami Mon, 04/20/2009 - 05:52
i downloaded the license
cue-vm-license_12mbx_cme_7.0.1.pkg
and it solved the problem, but i am not able to add a voice-mail application, and it is displaying:
Error: operation not allowed with this current installed license
Please advice
Moustafa
Abdo Ahmed Sale... Wed, 01/11/2012 - 22:27
Hi Moustafa
The license can't be change between CCM and CME support without a fresh install of the Cisco Uinty software.
Alkaff
paolo bevilacqua Thu, 01/12/2012 - 11:39
  • Hall of Fame,
    Founding Member
Incorrect. With recent CUE versions, mode can be changed with GUI.
Administration -> Control Panel -> Call Agent Integration.
vinhnguyen Fri, 09/23/2011 - 15:55
Hi Rob
I have a similar issues between CUE 8.5 with CUCM 8.5.  All I have as permanent license is 16 ports because I am using the system as auto attendant.  I have no voicemail license.  Would having no voicemail license cause the issue?
