BAT and primary extension
Apr 20th, 2009
have cucm version 7.0.2.10000-18.
I have ldap sync with AD.
I've imported phones and have been successfull at getting the association of phones to users to work.
I cannot get the primary extension to update.
I have only one instance of this extension in the system and are using the update users tab on bat sheet.
Also, in creating the user template i specified the subscribe calling search space and this is not updating either.
thoughts?
Overall Rating: 5 (2 ratings)
hbarrera2 Sun, 04/26/2009 - 16:04
I am having the same problem also on exact same version of CUCM. I am only having the problem with the primary ext field though.
Everything else is ok though, after I BAT'd all of my users/phones I also tried another BAT with just updating the users and no dice!
I think this may be a bug. I do know that thier is an ES8 out for our version of CUCM, but haven't had a chance yet to confirm this with TAC.
pvarenholt Sun, 04/26/2009 - 17:03
found the fix.
change primary extn field to text and put in format of "xxxx in "
that fixed it for me.
hbarrera2 Mon, 04/27/2009 - 07:19
So "6320 in DEVICES-P" you placed under the Primary Ext column...so 6320 is someones ext number and DEVICES-P is the partition?
For instance mine would be:
"81522 in Line1-PT"
pvarenholt Mon, 04/27/2009 - 07:21
That's it.
Kinda weird but whatever works right?
Hope this works for you.
hbarrera2 Mon, 04/27/2009 - 07:25
That is weird, the way the db is set up must be incorrect for this table/column, but hey whatever works!
I will try, thanks again!
Cheers.
Daniel Williams Fri, 05/03/2013 - 04:45
I am  working in a 9.1 system and had the same issue.  This did fix it though.  CRAZY
